I want to practice and build Power BI data analysis reports on Stack Overflow developer survey. Basically, there are two CSV files named Survey Results and Schema. How can I establish relationship between these two files? Or am I thinking wrong?
Hi @AnilKumarPoda ,
It need to be little bit transformed to get Responce ID, Questions and Answers side by side in the table.
Basic concept you can find in pbix:
Survey.pbix (9.7 MB)
Hope it helps.
Thanks for the response.
