How to do MTD and YTD side by side without creating a new measures
Hi Team,
I just want to present my KPI for MTD and YTD side be side like as follows:
Is there any demonstration to have that.
Thank you.
Regards,
Aye
@ammu,
You can create this visual as shown using the standard matrix visual with conditional icon and font formatting.
If you need additional detail, please provide a sample PBIX and I’d be glad to demonstrate.
Thanks Brian,
I would like to know application of DAX for TOTALYTD and TOTALMTD. If you come across some demo, please refer me.
PS: I am not looking for Conditional icon and font formatting. Sorry for confusion.
regards,
Aye
@ammu,
I think this should give you what you’re looking for:
You may also find this helpful:
Hi @ammu!
I think the Time Intelligence module provided by @BrianJ is what you are looking for.
You can also find Time Intelligence demos in the Enterprise DNA youtube channel.
I send you a couple of links that I think can help you as well.
  1. Types Of Time Intelligence Functions Ultimate Beginners Guide to DAX 2019
  1. Types Of Time Intelligence Functions Ultimate Beginners Guide to DAX 2020
Let me know if this works for you.
Cheers.
Yeriel
Hi @ammu, did the response provided by the contributors help you solve your query? If not, how far did you get, and what kind of help you need further? If yes, kindly mark the thread as solved. Thanks!
