How to display values inside the matrix in percentage %
How to show these numbers in percentage?
This is the original column in the power query source.
@MGadAllah - Create a measure for the column (SUM or AVERAGE as applicable) and wrap the measure in FORMAT DAX Function. Use this newly created measure in the Matrix Visual instead of the column.
Thanks a lot @pranamg my friend.
