Hi Experts,
I appreciate if you can shed some light on me
How can I show “ANSWER PRIOR YEAR” Column in the same table, BY PASSING THE CURRENTFILTER ON YEAR. I want the Current and Prior year to be dynamic. So with every new year’s data, I can only have the latest year compared to a year prior.
I have uploaded the image and workbook
I know VALUES isn’t correct to be used in my situation I am not sure what to use in “Red” for the expression in this calculate formula, i want to use allexcept to bypass the filter for year
ANSWER_Prior year = CALCULATE(values(Sheet1[ANSWER]),PARALLELPERIOD(Sheet1[Date],-1,YEAR),ALLEXCEPT(Sheet1,Sheet1[Question]))
Hereby a solution for in Power BI: (possibly there are other solutions)
Make a unique key with Power Query, “Add columns by Example” of “Org”, “small division” and “Question” together.
Make 2 new tables with DAX of current and last year (DAX does it automatically with every new upload)
Add a Lookup Formula in the Current Year table, searching for the Answer last year with the help of the Key, made in step 1.
Be aware that Lookup gives a error if no unique value can be found. This can happen if for the same key double lines of information or no data exists in LY , therefore “NA” or “To be Checked” should be added as alternative option, see formula used.
See the report and used formulas below and in attached PBIX below.
Ad 2 one of the two formulas used to create a new table:
TableCurrentyear =
var CY = RIGHT(YEAR( MAX(Sheet1[Date])),2)
return
CALCULATETABLE( Sheet1, Sheet1[FY] = “FY” & CY )
Ad 3 Formula used:
Answer LY = LOOKUPVALUE( Tablelastyear[ANSWER_CURRENT YEAR],
Tablelastyear[Key], TableCurrentyear[Key] ,“NA”)
Questions like this one in Power BI likely would get six different answers from six different people – each of them valid. So, here’s a different approach than the one provided by @deltaselect, but that gets to the same final answer.
First thing in any time intelligence–related question I do is add Enterprise DNA Expert @Melissa’s awesome Extended Date Table to the data model and be sure to mark it as a date table.
I then created a concatenated ID of question number and small division, , and then used the incredibly powerful offset fields in the extended date table as the basis for the following measure:
Answer Prev Year =
VAR SelID = SELECTEDVALUE( Data[ID] )
VAR SelFYOffset = SELECTEDVALUE( Dates[FiscalYearOffset] )
VAR LYFYOffset = SelFYOffset - 1
VAR Result =
MAX( Data[ANSWER_CURRENT YEAR]),
Dates[FiscalYearOffset] = LYFYOffset,
Data[ID] = SelID,
REMOVEFILTERS( Data ),
REMOVEFILTERS( Dates )
RETURN Result
If you are not familiar with the offset approach, I recommend the following video. This approach can be used to simply solve.a myriad of common and sometimes complex time intelligence problems.
Thanks so much for another way to resolve this issue. I haven’t had exposure to using offset and will certainly use it more.
much appreciated for your prompt help!
