Hi Guys,
i’m showing the rank in the line chart (The rank is the salesman comparing to his store)
In this way to present, means the 4º ranking is higher(better) than 1º…
anyone knows a way to demonstrate this where lower is better(higher)?
Hi Guys,
I would have thought just adding some simple text around your visual here would be sufficient…
Honestly though I think having this as a line chart over the bar chart is quite pointless. I would personally never do this. All you really should do is sort the bars in order from highest to lowest. Then the consumer can quickly see where each one is ranked without having to use something else in the visual.
That’s my opinion on this one.
