I am trying to create a running total of On Hand inventory by doing some Math in PowerBI. I’d like to take the existing quantity on hand and include quantity ordered for the orders for each inventory item. As the running total is calculated I’d like to use the most recently calculated value. See the screen shot for a better explanation of what I am looking for.
Hi @Preston, did the response provided by @Rajesh help you solve your query? If not, how far did you get and what kind of help you need further? If yes, kindly mark as solution the answer that solved your query.
Thanks for the response. What I need is the index by Item-SalesOrder. Attached is an updated PowerBI file that you can use. Use the Item-SalesOrder column highlighted below. Thanks for your help!
This is a great question, they want this to project how many orders they can fill with the existing inventory they have on hand. The ERP software shows on hand totals but does not do a very good job showing open orders against the on hand inventory levels. Make sense?
Hi @Preston, did the response provided by @Rajesh and @deltaselect help you solve your query? If not, how far did you get and what kind of help you need further? If yes, kindly mark as solution the answer that solved your query. Thanks!
Hi @Preston, we’ve noticed that no response has been received from you since the 25th of May. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved.
I am responding to this forum post as I originally thought the report that @Rajesh got for me was what I needed, however after some review of the data we have found some inconsistencies with the running total. I did some looking into the measures and could use some help! It appears to be something with the indexes that are causing the issue? The logic should be that the Qty Available (Cases) minus the Ordered amount should = Remaining. It does in in the first 3 examples but in the 4th example it does not…See my screen showing what I am referring too. I also attached an updated copy of the report as well.
@Rajesh Thanks for the quick response! This is closer…but if you scroll down on that list you will see that there are still some items where the logic doesn’t add up. See my below screen shot…
@Rajesh Thanks again for the response, however I am a little confused. See the screen shot below, the on hand quantity is not blank for the highlighted item “12105”.
