Please help, how to create a measure depending on the hierarchy level in the matrix?
Hello @Harris,
Well I’m providing a link of a video which was created during one of the “Learning Summit Series”. Although the video is related to the “Ranking Techniques” but it has incorporated the concept of “Hierarchical Problems” which is very much applicable in this scenario.
Using this technique as shown in the video you can solve this type of problem that you’re facing.
Hoping you find this useful and helps you to solve your problem. ![]()
Thanks and Warm Regards,
Harsh
Hi @Harris,
You can also refer to below link where we have DAX calculation for hierarchy
How to do Conditional Format referring to group average - #9 by MK3010
Following on to @MK3010’s post, the eDNA knowledgebase entry for ISINSCOPE has some great video and forum links:
https://info.enterprisedna.co/dax-function-guide/isinscope/
Other functions that are less commonly used for this purpose but also still helpful in special cases are ISFILTERED and HASONEFILTER.
https://info.enterprisedna.co/dax-function-guide/isfiltered/
https://info.enterprisedna.co/dax-function-guide/hasonefilter/
I hope this is helpful to you.
- Brian
@Harris Refer to my answer here:
