Hello,
I have some reports with row level security in Power BI Apps and showing/working as it should when someone doesn’t have access. The generic popup message shows as it should too.
Now I have a new request to create a more professional popup message with very simple message and look professional.
Question; Is there any way to achieve this? if yes please help with instructions.
Not aware of a way to do this. What you can do is to create a Main Page where can add Custom Error messages in textbox or on the first page itself can add Custom Error Messages in Text Box. By this way, User will be aware if he/she sees this Error message.
Thank you so much for following up on this. I just tried your suggested solution and it works but my superiors still want something that will not be on a separate page. I guess we will have to make do with this for now.
