My requirement is to create a barchart showing the revenue for pre-covid year 2019 and selected year side by side 2019 as a threhold bar . x-axis - dimension Y-axis- Revenue and should have two bars one for 2019 revenue and other selected year revenue. Can anyone help on this
Not sure if you have an example but here is one.
Bar Chart.pbix (43.4 KB)
AS an example i want a bar chart where the orange bar is constant 2019 year revenue and yellow is the revenue of selected year .
Thanks , i had a constant line to show up the target value to complete the requirement.
