Where do you get these strings from? If they are on the same row but different columns, you can use the concatenate DAX function. Do you have a data sample?
You need to convert the page number into a text and concatenate it with the rest of the expression .
The original expresion = “http://www.xyz.com?page=1" is all text.
Convert the number [page] into text with the expression “http://www.xyz.com?page=” & Number.ToText(page)&”
Don’t forget to add &" after the Number.ToText(page) so that it totally computes as per the original
expression.
eg with the expression above, for page = x, this is what would happen
“http://www.xyz.com?page=” & Number.ToText(x)&”
will return “http://www.xyz.com?page=x" which is the similar to the original expression.
This could help you figure it out.
Richard_D
Revision 1
PS On second thoughts, I could be mistaken since the topic refers to DAX and my solution applies to MCode.
