How to calculate the total number of reschedules appointment
Hi All,
Have a question, i am trying to find on how to calculate the total no.of reschedule happened based on the below scenario
Reasoning: Any appointment for any customer that has been cancelled a appointment but re booked it (seen) within 1 month or 30 day period is considered rescheduled.
Example:
Rows: 8 and 9, shows a reschedule because customer 1 cancelled the appointment on 03/11/2019 but re booked it (seen) on 04/08/2019.
Customer ApptStatus Appointment Date (MM/DD/YY)
2 Seen 01-01-2018
2 Seen 01-05-2018
2 Seen 01-09-2018
2 Cancelled 01-10-2018
1 Seen 01-10-2019
1 Seen 1/23/2019
1 Cancelled 03-11-2019
1 Seen 04-08-2019
1 Seen 10-09-2019
1 Cancelled 10-10-2019
1 Seen 10-10-2019
1 Seen 10/17/2019
1 Deleted 10/27/2019
1 Seen 1/22/2020
1 Seen 02-05-2020
1 Cancelled 2/26/2020
2 Cancelled 03-10-2020
2 Seen 3/15/2020
1 Seen 8/26/2020
1 Seen 10/15/2020
1 Seen 12/28/2020
1 Seen 1/13/2021
1 Seen 3/17/2021
rescheduled sample.csv (891 Bytes)
Hi there,
You may solve this issue with Countax or Countrows & Filter fucntions.
There is one condition in my calculation.
You can add your second condition
The following links can be useful.
https://info.enterprisedna.co/dax-function-guide/countax/
https://info.enterprisedna.co/dax-function-guide/countrows/
Good luck
@Nagi_k,
This one has a trickier filter context than it appears at first glance, but I think this gets you what you’re looking for:
Rescheduled =
VAR SelCustomer = SELECTEDVALUE( 'Table'[Customer] )
VAR SelDate = SELECTEDVALUE( 'Table'[Appointment Date])
VAR SelEndDate = SELECTEDVALUE( 'Table'[OneMonthLater] )
VAR Result =
IF(
    SELECTEDVALUE( 'Table'[ApptStatus] ) = "Cancelled",
    IF(
        COUNTROWS(
            FILTER(
                ALL( 'Table' ),
                'Table'[ApptStatus] = "Seen" &&
                'Table'[Appointment Date] >= SelDate &&
                'Table'[Appointment Date] <= SelEndDate &&
                'Table'[Customer] = SelCustomer
        )> 0,
         "Yes", "No"
    ), BLANK()
Result
– Brian
eDNA Forum - Rescheduled Solution.pbix (19.3 KB)
Hi @NagiK, did the response provided by @BrianJ and @IlgarZarbaliyev help you solve your query? If not, how far did you get and what kind of help you need further? If yes, kindly mark as solution the answer that solved your query. Thanks!
