How to build a model from two models w different connections
Hello everyone
I have two power bi files, each one a model. Sales has a SQL Database connection and Timetable has a MySql connection.
The purpose is to check if every records from Timetable are invoiced on Sales table. Both power bi files are very large, in terms of tables.
I wonder what’s your best advice for this issue.
Thanks a lot
Pedro
Hi @pedroccamara
This is a task for Power Query, please read the following post
Hello @jbressan
Thanks for the warning. Power query then.
About your answer, maybe i didn’t explain to well. I don’t have 2 tables, but 2 models and each one with its own connectivity.
Hi @pedroccamara
You can bring both table and used them on the same PBIX file, not matter what kind the connection, there are more than 100 connection and you can uses all them in the same PBIX.
Thank you @jbressan. Will do
Best regards
