How do you calculate the time difference between to two columns?
Hi Fellow Power BI Users -
I’ve managed to get the previous entry Date of a column using the following measure.
Previous Date =
CALCULATE( MAX('Driver Fatigue Summary Report'[Date Time]),
    FILTER( ALL('Driver Fatigue Summary Report'[Date Time]), 'Driver Fatigue Summary Report'[Date Time] < MAX('Driver Fatigue Summary Report'[Date Time])))
I’d now like to be able to calculate the duration between this measure and the value in the ‘Driver Fatigue Summary Report’[Date Time] field.
As you can probably guess the fields in each are in Date Time format such as 30/06/2018 2:09:00 PM
Hope you can help
Dave
Hi David,
Without recreating the wheel here. This link below offers a numbers of suggestions on this one.
Want to give this a look and see if you can integrate it into what you are doing.
There’s a query editor option (which I quite like)
Also a calculated column option as well which isn’t to bad either.
Let me know how it goes. Happy to look at your model if no luck with this.
Chrs
