David,
I have a PBI example to show the use of the Google API key as an invoked custom function. Unfortunately this is limited to 300 addresses, (Google have recently changed their licensing terms) , proper set up of the data and requires some special error handling. (try)
(Location)=>
let
Source = Json.Document(Web.Contents("https://maps.googleapis.com/maps/api/geocode/json?address="&Location&"&key=&GMAPIKey")),
results = Source[results],
#"Converted to Table" = Table.FromList(results, Splitter.SplitByNothing(), null, null, ExtraValues.Error),
#"Expanded Column1" = Table.ExpandRecordColumn(#"Converted to Table", "Column1", {"address_components", "formatted_address", "geometry", "place_id", "types"}, {"address_components", "formatted_address", "geometry", "place_id", "types"}),
#"Expanded geometry" = Table.ExpandRecordColumn(#"Expanded Column1", "geometry", {"bounds", "location", "location_type", "viewport"}, {"bounds", "location", "location_type", "viewport"}),
#"Expanded location" = Table.ExpandRecordColumn(#"Expanded geometry", "location", {"lat", "lng"}, {"lat", "lng"}),
#"Removed Columns" = Table.RemoveColumns(#"Expanded location",{"bounds", "address_components", "viewport", "location_type", "place_id", "types"})
in
#"Removed Columns"
Paul
