How do we connect Power BI to Oracle Business Intelligence Enterprise (OBIEE)
Hi All,
Can we connect power bi to Oracle Business Intelligence Enterprise (OBIEE) without a third-party connector? mentioned here, Power BI OBIEE Connector [Free Tool] | BI Connector?
Power bi seems to have a certified connector to OBIEE ( BI connector listed in the Get data option), but this requires installing a third-party driver from this particular vendor (which isn’t Free !?), any idea to workaround on this issue???
Thank you
Hi @jojo,
Yes you are right that there were a microsoft certified connector to OBIEE. There was a great read on how to connect OBIEE to power BI. Link is here How to Connect Power BI to OBIEE (us-analytics.com).
Cheers!
Hi @jojo, did the response provided by @ronald_balza help you solve your query? If not, how far did you get and what kind of help you need further? If yes, kindly mark as solution the answer that solved your query. Thanks!
Hi @ronald_balza,
Thank you for the excellent article but still, both ‘Unified BI’ and ‘BI Connector’ are third-party paid connectors. I was hoping for a direct connector from Power BI. My issue in this particular scenario is that I cannot directly construct my query from the Oracle DB because we don’t want to expose the tables, so the only option left is to read off from OBIEE subject areas.
Cheers!
Hi @jojo, thank you for giving additional details on your query.
We recently launched the Forum Survey, which enables us to review the members’ feedback and the improvement needed in the forum. Hoping you could take time to answer.
Hi @jojo! We noticed that your inquiry was left unsolved for quite some time now. We strive to answer ALL inquiries in the forum.
However, if you are sure that you provided all pertinent context to your concerns and read how to use the forum more effectively and still find your question unanswered, you can check out tutorials to learn this yourself as your membership also comes with relevant resources that may help you with your Power BI education.
