I apologize for the general question. I find i can’t use variables predictably, especially when I try to use the HASONEFILTER pattern to correct totals. I get the right results when I use the entire formula, but if I try to use variables, the results are incorrect.
Can anyone point me to resources that can illustrate how variables actually work?
@tigerec Always share complete information when you ask a question. I hope you understand if I ask you the same question you will have a hard time solving it. You can start by sharing DAX code and PBIX file that replicates the issue.
Thank you @DavieJoe your reply for SQLBI article is useful.
Glad to hear it @tigerec
Variables are really powerful, can make your code clearer and faster.
