Hi
Just wondering if anyone has used the Horizonal Bar Chart and might be able to help.
I have set up the chart but the top bar’s hammerhead and the number are being truncated.
Is there a setting to add space above so that the chart is being truncated? I can’t seem to find anything. I tried turning the Title on but it didn’t make any difference.
Hi @KieftyKids! We noticed that your inquiry was left unsolved for quite some time now. We strive to answer ALL inquiries in the forum. However, if you are sure that you provided all pertinent context to your concerns and read how to use the forum more effectively and still find your question unanswered, you can check out tutorials to learn this yourself as your membership also comes with relevant resources that may help you with your Power BI education.
