Hello Community - Our SF opportunity history table looks like the following. We can see the progress of two distinct opportunities…both of which ended converting to a win (100% - Closed). And we can see that the probability stage it was at just prior to converting to 100% (i.e. closed won) was 80%.
Of course not all opportunities convert at 80%. Some can convert at 60, 70, etc. No matter what, whatever the probability stage was just before the max createddate is the value we are looking for. Our goal is to be able to report the frequency of “won” conversions by each particular stage (probability). So the number of “Won” opportunities that converted at 30%…the number that converted at 40%, etc etc. Any help is appreciated! (the below can be pasted into Excel).
In the first 6 rows below, we can see that the opportunity started off at 80%…but eventually ended up at 0% (the equivalent of closed-won).
Our goal is to have a matrix table with two columns: closed-won closed-lost.
The rows would show the stages (10%, 20%…80%). And the values would be the frequency of occurrence that the conversion happened for each of the stages. In other words, how many opportunities flipped to closed-won at 30%, or 40% or whatever percent. Same for closed-lost.
I think the formula will need to find the max createddate (by opportunity ID) which should be the final disposition (either 0% or 100% depending on lost or won), and then Probability on the row prior to that which would be the stage it was at when it converted.
| OpportunityId | CreatedDate | Probability | ForecastCategory |
| 0065e00000ClR4iAAF | 10/1/2021 22:16 | 80% | Pipeline |
| 0065e00000ClR4iAAF | 10/2/2021 23:01 | 80% | Pipeline |
| 0065e00000ClR4iAAF | 10/5/2021 17:44 | 80% | Pipeline |
| 0065e00000ClR4iAAF | 12/13/2021 23:05 | 80% | Pipeline |
| 0065e00000ClR4iAAF | 12/13/2021 23:16 | 80% | Pipeline |
| 0065e00000ClR4iAAF | 1/13/2022 20:34 | 0% | Omitted |
| 0065e00000ClQhEAAV | 10/1/2021 22:16 | 100% | Closed |
| 0065e00000ClQhEAAV | 10/2/2021 22:59 | 100% | Closed |
| 0065e00000ClkHVAAZ | 10/5/2021 14:50 | 30% | Pipeline |
| 0065e00000ClkHVAAZ | 12/21/2021 18:48 | 30% | Pipeline |
| 0065e00000ClkHVAAZ | 3/14/2022 0:52 | 0% | Omitted |
| 0065e00000Clk3EAAR | 10/5/2021 12:45 | 40% | Pipeline |
| 0065e00000Clk3EAAR | 10/5/2021 12:53 | 40% | Pipeline |
| 0065e00000Clk3EAAR | 10/5/2021 13:09 | 50% | Pipeline |
| 0065e00000Clk3EAAR | 10/15/2021 15:58 | 50% | Pipeline |
| 0065e00000Clk3EAAR | 10/15/2021 16:01 | 50% | Pipeline |
| 0065e00000Clk3EAAR | 10/18/2021 18:04 | 50% | Pipeline |
| 0065e00000Clk3EAAR | 10/21/2021 18:33 | 50% | Pipeline |
| 0065e00000Clk3EAAR | 10/27/2021 21:12 | 80% | Pipeline |
| 0065e00000Clk3EAAR | 10/27/2021 21:22 | 80% | Pipeline |
| 0065e00000Clk3EAAR | 10/29/2021 14:26 | 80% | Pipeline |
| 0065e00000Clk3EAAR | 11/11/2021 19:18 | 100% | Closed |
| 0065e00000CliqTAAR | 10/5/2021 0:23 | 30% | Pipeline |
| 0065e00000CliqTAAR | 12/21/2021 17:21 | 30% | Pipeline |
| 0065e00000CliqTAAR | 1/14/2022 2:28 | 30% | Pipeline |
| 0065e00000CliqTAAR | 1/14/2022 2:29 | 20% | Pipeline |
| 0065e00000CliqTAAR | 1/14/2022 2:38 | 40% | Pipeline |
| 0065e00000CliqTAAR | 1/14/2022 2:38 | 30% | Pipeline |
| 0065e00000CliqTAAR | 2/3/2022 18:11 | 30% | Pipeline |
| 0065e00000CliqTAAR | 8/5/2022 14:57 | 30% | Pipeline |
| 0065e00000CliqTAAR | 8/22/2022 8:00 | 30% | Pipeline |
| 0065e00000ClhQsAAJ | 10/4/2021 17:35 | 30% | Pipeline |
| 0065e00000ClhQsAAJ | 10/6/2021 14:07 | 30% | Pipeline |
| 0065e00000ClhQsAAJ | 10/26/2021 13:03 | 30% | Pipeline |
| 0065e00000ClhQsAAJ | 10/26/2021 14:11 | 40% | Pipeline |
| 0065e00000ClhQsAAJ | 10/26/2021 14:11 | 50% | Pipeline |
| 0065e00000ClhQsAAJ | 10/26/2021 14:12 | 60% | Pipeline |
| 0065e00000ClhQsAAJ | 10/26/2021 14:12 | 70% | Pipeline |
| 0065e00000ClhQsAAJ | 11/30/2021 17:03 | 70% | Pipeline |
| 0065e00000ClhQsAAJ | 11/30/2021 17:06 | 70% | Pipeline |
| 0065e00000ClhQsAAJ | 12/6/2021 15:05 | 70% | Pipeline |
| 0065e00000ClhQsAAJ | 1/10/2022 20:24 | 70% | Pipeline |
| 0065e00000ClhQsAAJ | 1/22/2022 18:23 | 70% | Pipeline |
| 0065e00000ClhQsAAJ | 1/24/2022 17:01 | 70% | Pipeline |
| 0065e00000ClhQsAAJ | 2/14/2022 19:33 | 70% | Pipeline |
| 0065e00000ClhQsAAJ | 2/14/2022 19:39 | 70% | Pipeline |
| 0065e00000ClhQsAAJ | 2/14/2022 19:46 | 70% | Pipeline |
| 0065e00000ClhQsAAJ | 2/14/2022 19:52 | 70% | Pipeline |
| 0065e00000ClhQsAAJ | 2/14/2022 19:55 | 80% | Pipeline |
| 0065e00000ClhQsAAJ | 2/22/2022 20:43 | 80% | Pipeline |
| 0065e00000ClhQsAAJ | 2/22/2022 21:05 | 100% | Closed |
