while i’m able to do the conditional formatting to highlight the min/max values for each year in column charts for quarter & month (as shown in the sample file), i’m unable to do the same on the date/day-basis.
i managed to get the desired result for the month column chart using following dax formula
I’m sorry for my late reply too as I took some time to check the DAX formula which I have modified for other, similar conditional formatting at the date/day level in the application I’m trying to develop. So far, all seems to be working as I wanted it to be.
Meanwhile, as I’m rather new in DAX (particularly in the different context DAX implementations), can you kindly explain on how does your DAX formula work?
Here’s the explanation about why the old measure didn’t work and how it was corrected to achieve the results -
In the old measure, the function that was referenced was “ALLSELECTED()”. Now, this function works in similar manner in comparison to the “ALL()” function when nothing is selected on the report. So since there’re no slicers onto the report, the results which will be evaluated in this scenario is as good as “ALL()” function being referenced inside the measure. And therefore, it evalauted the MAX and MIN values for the entire time period i.e., for the both years 2015 and 2016. Below is the screenshot provided for the reference -
As you can observe in the above screenshot, eventhough the years change but the MAX values remain same for both the years. And therefore, since we want the MAX and MIN values for each year and not for the entire time frame. We made a usgae of “ALLEXCEPT() and VALUES()” function.
So when “ALLEXCEPT()” function is used, it removed the context at the Yearly level giving us the exact same results like you were getting it previously. Below is the screenshot provided for the reference -
But now, when we reference “VALUES()” function inside it, we are bringing in back the context which was previously removed from all the Years. And now, we’ll get two different MAX values for two different years i.e., one for 2015 and one for 2016. Below is the screenshot provided for the reference -
