I am trying to create a hierarchy level in my report for users to filter. I have a sample tables as the image below,
I am trying to create level 1 and 2 columns for users based on their Building so that I can create path measure. However, I have not yet been able to come up with a proper way to design the columns. I have tried manipulating the data in query editor using custom column (that would create an index of the ID and Level) and then do group by on the level. I realized it did not go as planned since I have a different row for each user. I am attaching the file here.
Hi @supergallagher25 , did the response provided by @BrianJ help you solve your query? If not, how far did you get and what kind of help you need further? If yes, kindly mark as solution the answer that solved your query. Thanks!
Hi @supergallagher25, we’ve noticed that no response has been received from you since the 4th of February. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the checkbox. Thanks!
Hi @supergallagher25, a response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box.
Also, we’ve recently launched the Enterprise DNA Forum User Experience Survey, please feel free to answer it and give your insights on how we can further improve the Support forum. Thanks!
