I have two measures Amount and Revenue Percentange, I have taken the measures on rows and dates in columns. Want to display the rev % for the top level only. The problem here now is I want to hide the rows other than for the total in the hierarchy. Could you please help if this is achievable.
If you are looking to hide rows, then the way to do this is somehow in the formula you need to include some BLANK() values for what you don’t want to show.
Something like the below.
IF( ISFILTERED( column name ), BLANK(), measure ) )
Tried this method, but its not working, tried to attach the screenshot but was not attached. I have attached again. As you can see I want to display data only for the total and hide the %ofRev rows. I have taken both the amount and %ofRev in rows. When I drill down the data should be displayed for the top level.
I saw your query in the newsletter and I was annoyed on your behalf at a simple issue being so hard to solve. I couldn’t figure out a way to exclude the lines if I used 2 measures and the visual itself. However, I was able to achieve a similar result using DAX in a single measure.
It isn’t exactly the solution you asked for but I think it’s quite close. The field will appear as ‘text’ so you need to right align the column when formatting the visual too.
