Hi Sam,
In a matrix visual, is there a way to hide columns without data? Or to put it another way, in my sceenshot below, is there a way to show ATTAINMENT only for the ACTUAL category but not for PLAN? Thanks!
Best regards,
Ferdinand
Hi Sam,
Best regards,
Ferdinand
In Visual Level Filters should be able to say only show “attainment” that is not blank, null, or zero. which ever of those you use for that column.
Jarrett
