Hex to R,G,B in Power Query (M Code)
Hello everyone I’m working on a project :
I got a table with two columns
Brand and Colors
Where some brands have mapped to them hex colors
Like :
Brand 1 → #000000
Brand 2 → null
Brand 3 → #000000
Brand 4 → #EFEFEF
and I want to be able to add 3 columns with the relative value of R , G , B.
That’s my first task to be able later to slightly change (for example) the value of G (like+1) in case of dupes for the color mapped to different brand ( to make it different by code but not noticeable by watching it )
And Then being able to change it back to Hex.
If you guys have alternatives I’m all ears!
Thanks !
Hi @tom071136 ,
If you looking for conversion algorithm you can find them at:
Good luck with your project.
I think this M should do the conversion: InclusivePBI/PQ/fnGetRGBValue.pq at main · cbaragao/InclusivePBI (github.com)
This one should convert back: InclusivePBI/PQ/fnGetHexValue.pq at main · cbaragao/InclusivePBI (github.com).
I guess all you need now is to do the math in the middle.
