The situation I have is that a payout report needs to be generated every month, but every 3rd month the report generated should be a quarterly report.
Now I know that If I just place a parameter that allows the multiple selection of months, I get the required result. However, under the of the report I prefer to have a ‘Period’ mentioned. Something like Period: Q3 or Period: July 2022, Aug 2022, Sept 2022
In this case, if create a placeholder, it only displays a single value even if Multiple months have been selected in the parameter. (I am not aware if there is a way to show multiple values using a place holder, if so, that could be my solution)
So, I was thinking if there was a way to set a parameter Asking for a report to be Quarterly or Monthly report. And based on this selection, a Second Parameter may become visible either showing Quarters or Months (single selection in both cases)
This will help me display the selected value in the placeholder on the report
Any Suggestions or guidance to reference material will be helpful.
Thanks.
