Hello Everyone,
I am having trouble with the map visual in Power BI. We are trying to show client home addresses on a map (one dot per client) but we have multiple clients with the same address and different apartment numbers and we only see one dot on the map.
We have the Street, Apartment, City, State and Zip code all labeled properly as an address but cannot seem to get around this. Has anyone in the community solved this?
Hi @JeremyH, we aim to consistently improve the topics being posted on the forum to help you in getting a strong solution faster. While waiting for a response, here are some tips so you can get the most out of the forum and other Enterprise DNA resources.
- Use the forum search to discover if your query has been asked before by another member.
- When posting a topic with formula make sure that it is correctly formatted to preformatted text </>.
Hi @JeremyH, we noticed that you have not responded to our request above. We are waiting for the masked demo pbix file, images of the entire scenario you are dealing with, screenshot of the data model, details of how you want to visualize a result, and any other supporting links and details. In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved.
Hi @JeremyH, due to inactivity, we’ll be marking this post as solved.
Should you wish to reopen this thread, kindly provide the PBIX file requested above so other users can help you further.
