Help with dax please
Hey All,
looking for some support here with dax.
I have this single table PBI with sample data attached. and here is the scenario:
The idea is that Any combination of 2 slicers can be used in the report, the final output needed is count of ID’s that have an aggregated value ( based on applied filters) > = 1000
I have been able to get the numbers in the table, to identify the id’s that are >1000, and seem to work alright in the table.
But the issue remains in the card visual - that’s what should eventually tell the count of ID’s with revenue> 1000, currently, it doesn’t change when filters are applied.
my current measure is :
ID’s with revenue >1000 =
VAR _v1 =CALCULATE(SUM(TestTable[Revenue]), REMOVEFILTERS(‘TestTable’[Sub.PricingItemName] ))
VAR _v2 = CALCULATE(COUNTROWS(VALUES(‘TestTable’[Accountid])), FILTER(TestTable, _v1 >=1000))
VAR _v3 = CALCULATE(_v2, ALLEXCEPT(TestTable, TestTable[Sub.Platform],TestTable[Accountid]))
Return
_v3
would appreciate your guidance with this.
Sample report1.pbix (31.7 KB)
Hello @jsodhi,
In order to achieve the results based on the scenario that you’ve mentioned. Below is the DAX measure alongwith the screenshot of the final results provided -
IDs w/Revenue Threhold - Harsh = ----- 'Count of ID's with Revenue More Than or Equal To 1000'
VAR _Count_of_IDs_wrt_Revenue_More_Than_or_Equal_To_1000 =
COUNTROWS(
    FILTER(
        ADDCOLUMNS(
            SUMMARIZE(
                TestTable ,
                TestTable[Accountid] ,
                TestTable[Sub.PricingItemName] ,
                TestTable[Sub.Platform] ,
                TestTable[Sub.OfferName] ,
                TestTable[Revenue] ) ,
            "@Revenue" ,
            CALCULATE( SUM( TestTable[Revenue] ) ,
                ALLEXCEPT( TestTable , TestTable[Accountid] , TestTable[Sub.Platform] , TestTable[Sub.OfferName] ) ) ) ,
        [@Revenue] >= 1000 ) )
VAR _Results =
IF( NOT ISBLANK( _Count_of_IDs_wrt_Revenue_More_Than_or_Equal_To_1000 ) ,
    _Count_of_IDs_wrt_Revenue_More_Than_or_Equal_To_1000 ,
    0 )
_Results
Thanks and Warm Regards,
Harsh
Count of IDs w.r.t Revenue more than or equal to 1000 - Harsh.pbix (34.6 KB)
Hey @Harsh ,
Thank you for your response. The solution you have shared gave correct result only in one of the possible scenarios. ( combination of filter being used) - thats probably because i didnt explain the scenarios very well in my previous post
I had also been working on the solution and looks like i was taking the same approach as you did. but was slightly off . and looking at your solution helped me fix mine.
[The version2 CountRevenue >1000] gives me the result that i was looking for - the measure also has my old code commented out
here is the working pbx
Sample report2nd attempt.pbix (35.0 KB)
Although I think like problem is resolved, would be great if you can have a look at DAX and share any feedback incase you think it can be improvised
Either ways - I really appreciate your support. Thanks,.
