Help with code optimization
I am asking for help in optimizing the following metric.
% of Sales revenue =
IF (
    SELECTEDVALUE ( PnL[Position Level2] ) = "Online"
        && SELECTEDVALUE ( PnL[Position Level1] ) = "COGS",
    DIVIDE (
        [P&L AC],
        CALCULATE (
            [P&L AC],
            ALL (
                PnL[Sortowanie level 1],
                PnL[Position Level1],
                PnL[Position Level2],
                PnL[Sortowanie level 2]
            PnL[Position Level1] = "Sales revenue",
            PnL[Position Level2] = "Online"
        0
    ) * 100,
    IF (
        SELECTEDVALUE ( PnL[Position Level2] ) = "Offline"
        DIVIDE (
            [P&L AC],
            CALCULATE (
                [P&L AC],
                ALL (
                PnL[Position Level2] = "Offline"
            0
        ) * 100,
        IF (
                && SELECTEDVALUE ( PnL[Position Level1] ) = "Gross margin",
            DIVIDE (
                [P&L AC],
                CALCULATE (
                    [P&L AC],
                    ALL (
                0
            ) * 100,
            IF (
                DIVIDE (
                    [P&L AC],
                    CALCULATE (
                        [P&L AC],
                        ALL (
                    0
                ) * 100,
                DIVIDE (
                    [P&L AC],
                    CALCULATE (
                        [P&L AC],
                        ALL (
                    0
                ) * 100
Sending out the signal for the Antman, @AntrikshSharma
antman
@Harris Since you are repeating same thing again and again and only changing one statement in CALCULATE, just create a table with ADDCOLUMNS and add new column for P&L AC and then based on the condition use a FILTER to filter the result and maybe create 3-4 variable for the DIVIDE part, make sure that the ADDCOLUMNS part is computed in a variable before IF or you can use ADDCOLUMNS inside IF with IF.EAGER.
@AntrikshSharma There is a problem because I am using a live connection and I cannot create columns
@Harris Why wasn’t this included in your original post?
@AntrikshSharma Sorry, I thought it didn’t matter
@Harris I meant using ADDCOLUMNS inside the measure, like a virtual table.
