Hello All,
I am a beginner and have a basic understanding of Power BI and DAX.
I have had a sample dataset ( CSV file attached) with me for quite some time and had a mental block, about where to start from. i.e, how to model it? how to break the table down etc.
Well after spending several hours I came up with this (pbix file attached)
Please can you help me with the following :
1 - your feedback and suggestions if I have modeled it correctly and if there is anything I could improve
2- I created a measure called [Total Wine spend], that I was hoping to display based on age group ( the calculated column that I had created) - Well that isn’t working, I can get the age group in the table, but as soon as I add the measure [total wine spend], the age group disappears.
marketing analysis pending.pbix (228.0 KB) marketing_data.csv (220.4 KB) marketing_data_dictionary.csv (1.7 KB)
