I have scenario where I need to append the files but with a twist where I have 3 files in folder but when I append I should get week 1 data in week 2 and week 1 & 2 in week 3 data and also this should dynamic if I get 4th week.
Basically I need the latest table to be combination of previous versions.
Any help on the same, I have attached small sample file and end result screenshot I wanted…
Hello @ @Dharma, just following up if the response from @Melissa help you solve your inquiry?
We’ve noticed that no response has been received from you since a few days ago. In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved.
Hi @Dharma, due to inactivity, a response on this post has been tagged as “Solution”. If you have any concern related to this topic, you can create a new thread.
