Hi @stevens, we aim to consistently improve the topics being posted on the forum to help you in getting a strong solution faster. While waiting for a response, here are some tips so you can get the most out of the forum and other Enterprise DNA resources.
Please also check the How To Mask Sensitive Data thread for some tips on how to mask your pbix file
