I have a question from the above video. At 2:20, the example being discussed suggests is VALUES(customers[customer Names]), this gives the error, and the error is being caused by the total. So the solution for this used to be IF(HASONEVALUE(Customers[Customer Names] ), VALUES(customers[customer Names]), BLANK() )
My questions are :
The first question that came to me is what if I turn off the total formatting section and then try VALUES(customers[customer Names]), - well I tried that and it still didn’t work.
- So how is it that it didn’t work when there was no total required in the table.
The Second question is how wrapping up the above formula in “IF(HASONEVALUE)” or “SELECTEDVALUE” resolves the previous error that was caused by total.
I think in both cases I havent understood the background of the relationship with total, Can you put me in the right direction
