The half scenario is illustrated in the image, Now Masterbrand is based on company. means Company have many brands. I got the Top 5 companies, but now want to see the only brands of the already filtered companies. but when I select the select all option in Company slicer it shows all the brands in the Masterbrand slicer.
For Example, Loreal company have 5 Brands and rest 4 have 1 brand each, then it should show only, 9 brands in the Masterbrand slicer when Select all is selected in the Company Slicer. Selecting the only one Company from the Slicer works fine, without any dax calculation.
Any solution? Any one can provide the solution or their thoughts and hints are also valuable for me. but, @sam.mckay, its urgent and i know you will provide the solution quickly
Note: Company and Masterbrand slicers are from the same table
Hi @iamafanijaz, we aim to consistently improve the topics being posted on the forum to help you in getting a strong solution faster. While waiting for a response, here are some tips so you can get the most out of the forum and other Enterprise DNA resources.
Hi @iamafanijaz, we noticed that you have not responded to our request last Sept 5th. We are waiting for the masked demo pbix file, images of the entire scenario you are dealing with, screenshot of the data model, details of how you want to visualize a result, and any other supporting links and details. In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved.
Ah ! i need to create the demo file for it, as i am working on db that is connected to server via vpn, and i did not have access to it, so its a little time taking. i will replicate the requirement in demo file and share ASAP.
Hi @iamafanijaz, due to inactivity, a response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box.
