I don’t think there will be any performance difference in CROSSFILTER vs Bi-Directional filtering, however TableExpansion proves to be much efficient in contoso dataset. I the below example I am trying to get the list of Categories from which each customer bought.
Here are the queries generated by
Bi-Directional filtering:
Which Category they bought from =
CONCATENATEX (
VALUES ( ProductCategory[Category] ),
ProductCategory[Category],
CROSSFILTER ( no difference in both )
Which Category they bought from CrossFilter =
CALCULATE (
CONCATENATEX (
CROSSFILTER ( Sales[ProductKey], Products[ProductKey], Both ),
CROSSFILTER ( Products[ProductSubcategoryKey], ProductSubcategory[ProductSubcategoryKey], Both ),
CROSSFILTER ( ProductSubcategory[ProductCategoryKey], ProductCategory[ProductCategoryKey], Both )
Table Expansion: Wins the match
Which Category they bought from ExpandedTable =
CALCULATE (
CONCATENATEX (
Sales
So the answer is “it depends”, one code will be not be the best one for every model you have to play with it and find what works best for you.
