I hope you are well. I have come across an issue in our mode. I am trying to group products or Customers into virtual group. Unfortunately the standard grouping option is disabled in our mode. Can you help with a DAX to achieve the grouping?
Thanks for the response, so i see you make reference to the new table created. .Unfortunately my model has blocked that as well. in the meantime i tried to use a quick measure to create this group with the filter function
Grouping Test =
[Sales YTD],
‘Product’[BRAND] IN {
“brand1”,
“brand2”,
“brand3”,
“brand4”,
“brand5”,
“brand16”,
This returned some values but every single line had the same amount. and reading to the blogs , it seems i am missing something in my formula but i dont know what. Please help
Your DAX actually looks spot on to me , and to confirm that I replicated your measure using the External Tools Practice Dataset, and it performs exactly as expected per the screenshot below:
Thus, I am left to the conclusion that the problem lies somewhere in your data model. If you can please provide a copy of your PBIX file, or at minimum a screenshot of your data model that will help us sort out exactly what the problem is and how to fix it.
