Please find Attached file. I want to use a graph showing numbers by month. But since the Budget is showing two times (oct, nov and dec for both 2018 and 2019) the graph dosent show the correct numbers. Any way to go around that problem? It should be a separate line
If you see in the Budget column there are both November 2018 and November 2019. I want one seperate line showing 2018 and one line 2019. Otherwise it will be one line showing over the years. In that way its hard to see the difference between the years.
