Has anyone recreated something similar? To me it looks like three overlapping shapes 2 squares and a triangle? Or if anyone has an easier way to build this bar it would be helpful
If you’re willing to use custom visuals, I think you can get pretty close to the desired look of this (but for the triangle portion, which you’d have to add separately) using Cards with States.
This visual gives you enormous control over the look of your cards. It’s developed by OK Viz (the SQLbi guys), who in my opinion make the best custom visuals. Even the premium version of this is now free. I have started using this pretty extensively in my own reports, and have attached a PBIX file from OK Viz that provides a tour of its features and capabilities.
I hope this is helpful.
- Brian
cardWithStatesByOKViz-tour.pbix (3.1 MB)
