Get correct titles from Sharepoint
Hello,
I have a table in sharepoint that has over 50 columns and some of them are nested. When I link it to PowerBI, I end up getting the internal column names. I was able to extract the external column names following this guide
However, it arrives in an unpivot format. And I can’t really pivot the columns on the actual table since there are nested columns inside.
I have tried to create a list out of the query that I had created using the PowerBI link and then insert it as a step into the other table by using the following statement,
Table.RenameColumns(#“Changed Type”,#“Headers”,MissingField.Ignore)
And it gives me the following error
Hi @supergallagher25
Can you please share the sample list structure you have and the Output that is required in a spreadsheet or table. Also, the issue that you are facing.
Once provided with this information, we will be able to help you.
Ankit J
Hello @supergallagher25
If you could provide sample .pbix file that should be great.
Regards
Kumail Raza
Hi @supergallagher25, we’ve noticed that no response has been received from you since the 8th of June.
We are waiting for the masked demo pbix file and any other supporting links and details.
