If you want to achieve the above output assuming the percentage as per of total for one category.
I think you need to create a cal table form which you can dynamical find out your avg gap max and min .
If i get your output right you can give my idea a try.
Yeah! I have a BIG smile on my face thanks to you pointing me in the right direction!!
I managed to create filtered virtual tables (so the user didn’t need to use a slicer) and then create min and max score… but then I also created without a filter inside the measures… and I think this is better because it enables me to create one graph and table that I can filter depending on the categories.
So yes, a big THANK YOU for pointing me in the right direction. I now have min and max score for each category and each indicator or group of indicators… Wonderful! Moved up another notch regarding virtual tables!
