FYTD Hours calculation
Hi Experts,
I have below dax codes to calculate YTD numbers. Is there a workout to override the external filters on dates in this formula i.e., even i applied for filters on dates, total ytd number should not change ?
VAR YTDHours =
if(
    HASONEVALUE(Dates[FY]),
    CALCULATE([Charged Hours],
        FILTER(
            ALL(Dates),
            Dates[FY]=VALUES(Dates[FY])
            && Dates[FY]="FY 21"
            && Dates[Calendar Dates]<=MAX(Dates[Calendar Dates])
    BLANK()
VAR LastChargedHoursdate=MAXX(ALL(ChargedHours[Period Ending Date]),ChargedHours[Period Ending Date])
IF(MIN(Dates[Calendar Dates])<=LastChargedHoursdate, YTDHours,BLANK())
Hi @nbaraili,
I’m not sure why you would want to hard code the information into the coding.
Could you please load your file, so we all can help you with a solution?
thank
Keith
Hi @nbaraili , we aim to consistently improve the topics being posted on the forum to help you in getting a strong solution faster. While waiting for a response, here are some tips so you can get the most out of the forum and other Enterprise DNA resources.
Hi @nbaraili, we’ve noticed that no response has been received from you since the 19th of July. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the checkbox. Thanks!
