I need to construct financial statements in a “functional currency” (NZD) and then translate into another currency (AUD).
The balance sheet end of month balances need to be translated at the End of Month Rate and the Profit and Loss transactions need to be translated at the Average Rate of the month.
I am able to translate the P&L data but I am having difficulty in calculating the running total per month for each balance GL-account and then translate that to the AUD currency.
Hi @grant, we aim to consistently improve the topics being posted on the forum to help you in getting a strong solution faster. While waiting for a response, here are some tips so you can get the most out of the forum and other Enterprise DNA resources.
When posting a topic with formula make sure that it is correctly formatted to preformated text </>.
Include demo pbix file, images of the entire scenario you are dealing with, screenshot of the data model, details of how you want to visualize a result, and any other supporting links and details.
Hi @grant, we’ve noticed that no response has been received from you since the 30th of March. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the checkbox. Thanks!
It did not resolve my problem. My problem which I am not sure how to fix is as follows:
I need to summarise the balance sheet accounts for each period and then using a ‘end of Month’ exchange rate to translate the balance from NZD to AUD for example.
