Hello. I have a column “Hold Time”. This Column Originally Displayed time as for example 0.00:00:07
I Transformed it to Total Minutes and it gave me a column “Hold Minutes” showing above time as 0.116666667
I used this to Create a Measure “Average Hold Minutes” and it worked fine.
Since this Hold time is also Same as time taken to answer a call, I Now need to calculate Number of calls & % of calls that were answered in less than 60 seconds and Those that were answered in less than 30 seconds.
I can do this by creating another column Converting “HoldTime” to Seconds and creating these measures,
Is there a better way to handle this ? a Smart way ? so I can avoid creating this new Column
Hi @jps, I noticed you didn’t provide a PBIX file. Providing one will help users and experts find a solution to your inquiry faster and better.
A clear explanation of the problem you are experiencing
A mockup of the results you want to achieve
Your current work-in-progress PBIX file
Your underlying data file (to allow us to go into Power Query if necessary to transform your data and/or data model – often DAX questions really end up being data modeling solutions)
Hi @jps, good to see you are having progress in your inquiry.
Did the response provided by @Melissa help you solve your query? If not, how far did you get and what kind of help you need further? If yes, kindly mark as solution the answer that solved your query. Thanks!
