Can someone tell me what is wrong with my syntax? I have a dynamic chart title and format both fixed and percent numbers. The % numbers is working but I can’t for some reason get the fixed number to work. I want a “,” to so seperate the thousands. In the below example, I want to show 1,585.
Thanks for your help.
My formula is
"Top " & SELECTEDVALUE(TopNSelection[Value]) & " campaigns contributed " & Format(TopNSelection[Top N SUM], “#.#, which is " & FORMAT(TopCampaignPct,”#.#% of all campaigns in " &SELECTEDVALUE(‘Date’[Qtr-Yr]) ))
Hi @ysherriff. It looks like your trying to include text in your FORMAT commands; when I split your measure onto separate lines ending in the “&”, it looks like this:
Wrong =
"Top " &
Format(TopNSelection[Top N SUM], "#.#, which is " &
FORMAT(TopCampaignPct,"#.#% of all campaigns in " &
SELECTEDVALUE('Date'[Qtr-Yr])
I’m guessing you’re trying to achieve something like this:
Perhaps Right =
"Top " &
SELECTEDVALUE( TopNSelection[Value] ) &
FORMAT( TopNSelection[Top N SUM], "#.#") &
", which is " &
FORMAT( TopCampaignPct, "#.#%") &
" of all campaigns in " &
SELECTEDVALUE( 'Date'[Qtr-Yr] )
If you’d like to pursue further, please attach a work-in-progress PBIX file with a marked-up screenshot of the visual in question and what is your desired outcome.
Thanks Greg. Please see the attached file. Also, is there a way on the Color measure under TopNSelection table that I can format each bar of the column bar a different color. Keep “Others” grey but the other bars varying color.
Hi @ysherriff. Just adjust the first FORMAT string as desired, like:
Campaign Title 2 =
VAR TopCampaign =
[Total Campaigns],
TOPN(
SELECTEDVALUE( TopNSelection[Value] ),
ALLSELECTED( 'Campaign Table'[Campaign Name] ),
[Total Campaigns]
VAR TopCampaignPct =
DIVIDE( TopCampaign, [Total Campaigns] )
"Top " &
FORMAT( TopNSelection[Top N SUM], "#,#.#" ) &
" , which is " &
FORMAT( TopCampaignPct, "#.#%" ) &
" of ALL campaigns IN " &
I’ve attached my sandbox PBIX in case it helps.
As for the bar colour, I think you have the conditional formatting setup correctly, however in the few minutes I had available to look, I couldn’t get the “Others” line/bar to show in the visual, so couldn’t check further.
