If you only need to switch the measure being used for the table visual, I recommend bookmarks
with a few tricks, you can even have a bookmark that looks like it’s a visual filter:
For the attached solution, I created two pairs of buttons, each pair has an “On” state, and a “Show” state
I opened the Selection pang, and named the buttons, so it was clear what which button was for “On” and which was for “Show”
the “On” state has only the default dark box (like Amt in the image above)
The "Show" state is the interactive button, so I actually changed the icons between 'default', 'hover', and 'press' (this isn't necessary - but I like to give my users the a clue that this is interactive)
I made sure that the Amt buttons overlapped one another, and the Unit buttons overlapped each other.
I next, I made chart visuals, one using the “Sum $” measure, the other using “Sum Unit”
And I made sure the charts overlapped as well
Finally, I created two bookmarks
Units Bookmark has this state for the visuals:
and the show/hide state is reverse for the Amt bookmark:
Finally - the appropriate bookmarks were attached to the “Show” buttons
Hi @Cedric, did the response provided by @Heather help you solve your query? If not, how far did you get and what kind of help you need further? If yes, kindly mark as solution the answer that solved your query. Thanks!
