But whenever I run the measure, the values lose their formatting. I tried wrapping it with CALCULATE() function in FORMAT(), but the values ended up not showing in my charts. How can I retain the formatting in this scenario?
It can be done by simply going to the Data Modeling area, and then click on your measure and click on the $ icon to format the measure as currency.
You donāt need to use FORMAT for simple things like this. Just utilize the formatting feature. You only have to format it once this way and then youāre done.
Iām running into this issue as well and I have formatted the column as currency but when displaying the visuals they only come out as numbers with M, or Bn to denote any kind value.
Hello @DDewbre, this sounds like a visual display issue - you need to check the formatting pane for that visual in the visualizations panel.
Select the visual that is showing the value you want to correct
Find the area (in formatting section ) that is dealing with Data lables or Data values (what it is called depends on what type of visual you are using)
next you need to look for the āDisplay Unitsā drop-down, you can change this from Auto (default setting) to show the value in a particular unit type (such as āMā or āBnā)
Selecting āNoneā will show the value as you have defined it.
Change Display units from āAutoā to āNoneā, that should fix it.
NOTE: with a number going into the billions, you may need to expand that card visual.
It didnāt, it just showed the full valueā¦but no $ sign. This is why Iām confuzzled because this is the first time Iāve had this issueā¦itās like an update changed something. Actually is doesnāt show in any of the visualsā¦including charts.
Very strange, I havenāt run into anything like this yet.
I havenāt done any design work since late in January, so itās always possible that an update changed things.
Is it possible for you to post a condensed version of your model?
Interesting, I went back to an older report and the $ is showing on those visuals. Let me do a comparison and see if I did something different on the old oneā¦I doubt itā¦but maybe.
So it looks like it might actually be a field issueā¦maybe. Iām looking at one of my new reports and I have half of them showing with $ signs and half not. Very interesting.
Hey, itās Friday, I think we all need to allow for a bit of what I call ābrain fuzzā at times.
Iām glad the solution was a simple one, believe me, Iāve had plenty of times that I was SURE Iād done everything right, but there was one simple piece that was missed.
And most PowerBI development has a LOT of places where a small detail makes all the difference.
Have a good weekend!
