Hi all,
Does anyone know if there is an automated way, to export data from a table in a published power bi report table to a CSV file (and store it somewhere), each time the report is auto refreshed?
Many thanks
Hi all,
Many thanks
Hi @Jeff91, did the response provided by @jbressan help you solve your query? If not, how far did you get and what kind of help you need further? If yes, kindly mark as solution the answer that solved your query.
Hi @Jeff91, we’ve noticed that no response has been received from you since October 25.
Hi @Jeff91, due to inactivity, a response on this post has been tagged as “Solution”. If you have any concern related to this topic, please create a new thread.
