I want to create a table measure which do the group by 3 column shown in the below image and after doing that want to get first min and second min so i can subtract it from one another and get a number .
Hi @Anurag, we aim to consistently improve the topics being posted on the forum to help you in getting a strong solution faster. While waiting for a response, here are some tips so you can get the most out of the forum and other Enterprise DNA resources.
Hi @Anurag, we’ve noticed that no response has been received from you since the 19th of January. We are waiting for the masked demo pbix file and any other supporting links and details.
This will help other users and experts to answer your inquiry better. In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved.
