Please help. I would like to filter the same column with two different date filters on one table
Sample.pbix (140.7 KB)
Sample.pbix (142.6 KB)
Harris, hello!
You need to use ALL (to reset filters) after CALCULATE in your sales measure.
When you need to exclude Calendar_1 this is equal ALL ( âCalendar_1â).
When you need to exclude Calendar this is equal ALL (âCalendarâ).
I add this into your file (attached).
Does it help you?
Happy new Year!
BR,
Oleg
Hello @Harris, just following up if the response from @Oleg.Poddubnyy help you solve your inquiry?
Weâve noticed that no response has been received from you since a few days ago. In case there wonât be any activity on it in the next few days, weâll be tagging this post as Solved.
Hello @Harris, itâs been a while since we got a response from you.
Please be reminded that In case there wonât be any activity on it in the next few days, weâll be tagging this post as Solved.
Hi @Harris, due to inactivity, a response on this post has been tagged as âSolutionâ. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box.
