I am creating a report in Reports Builder. I’m making about 30 slicers in the report but I’m having a problem with one of them. This is a column with id_produkt. There are approximately 5 million unique entries in this column. The Paginated Report works by loading all elements in the “fragmentator” visualization, which puts a heavy load on the Power BI tenant, which makes the entire report run very slowly.
How should I create a slicer in .rdl that will have the option to search for a specific produkt_id?
Hi @Harris ,
To create an efficient slicer in your .rdl report for searching a specific produkt_id:
- Create a Parameter:
- Add a parameter named
ProduktIDSearch (Text type) to your report.
- Modify the Dataset Query:
sqlCopy codeSELECT produkt_id, other_columnsFROM YourTableWHERE (@ProduktIDSearch IS NULL OR produkt_id LIKE '%' + @ProduktIDSearch + '%')
- Add a Parameter Input Field:
- Add an input field in the report layout for
ProduktIDSearch.
- Configure the Slicer:
- Bind the slicer to the filtered dataset using the
ProduktIDSearch parameter.
For more solutions, feel free to explore Data Mentor (https://mentor.enterprisedna.co/).
Kind regards,
Enterprise DNA Support Team
