Filter two tables and get the result
HI
I am trying to Filter a fact table based on column values in the filter table and also in the fact table.
Basically from PBIX I want to recreate that stacked column graph visual that I have created using drop-down filters but without those drop downs so a permanent graph.
The result I want is a table that shows me all the results for ‘Operation Short Text’[Power BI Details] = “Final Bag”
and filter only results in the fact table that meet the ‘SQ00 Confirmations’[Project Number] = “601” && “602” && “603”
Dan
Total Pilatus Final Bags Completed =
CALCULATE( [Total Confirmations],
    FILTER('Operation Short Text',
    'Operation Short Text'[Power BI Details] = "Final Bag" &&
    FILTER('SQ00 Confirmations',
    'SQ00 Confirmations'[Project Number] = "601" && "602" && "603"
Pilatus CCA.pbix (4.1 MB)
Thought i just solved it but i haven’t
It locks in the Final bag operations but when I change the drop down filter for project numbers it still filters the chart visual I want static
    'Operation Short Text'[Power BI Details] = "Final Bag"),
    'SQ00 Confirmations'[Project Number] = "601" || "602" || "603")
Hello @Krays23,
Well, the reason why it was still filtering the results is because slicer is created out of a Dimension Table i.e., “Project Numbers” and within the measure you’re referencing the Fact Table Column i.e., “SQ00 Confirmations[Project Numbers]” and therefore although the Project Numbers were hard-coded i.e., “601, 602 and 603” still it used to filter out the results. Just change the reference within the measure to the Dimension Table. Below is the measure alongwith the screenshot of the final results provided for the reference -
CALCULATE( [Total Confirmations] ,
    'Operation Short Text'[Power BI Details] = "Final Bag" ,
    'Project Numbers'[Project Number] IN { "601" , "602" , "603" } )
Now, in the above screenshot, if you observe, irrespective of the slicer selection it’s giving the static results where Project Numbers equals “601, 602 and 603” and Power BI Details equals “Final Bag”.
Thanks and Warm Regards,
Harsh
Pilatus CCA - Harsh.pbix (4.1 MB)
Thank you Sir, Great explanation and makes it very clear many thanks.
Never seen the DAX written with the IN { before whats the benefit of that rather than = 601 || 602 || 603
