I did Filter top N products with a row for others please refer to the following link:
My Question is if I need to pass any of the product names in the TopN table to another report for (Drill through) , how can I pass it to the column (Product Name) from Table (Products Name) to the Product table in the Drill through report?
Note:
I asked this question because sometimes the product name in products table is duplicated names but with Unique Identifier , I need to pass the Unique Identifier e.g. (Barcode) to the Drill through Report , In the youtube example it use the product name only without it’s Unique Identifier , How can I edit the Product Names table to Include (2) columns Uniqe Id , Product name?
This is an incredibly clever technique that you can use to ensure that your product names are unique, even if visually they look the same (through the use of nonprinting characters).
Hi @MAAbdullah47, did the response provided by @BrianJ help you solve your query? If not, how far did you get and what kind of help you need further? If yes, kindly mark as solution the answer that solved your query.
Hi @MAAbdullah47, we’ve noticed that no response has been received from you since the 21st of June. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved.
